SOLVED Ungula - little sound, must attack hard
Hello Lovely and powerful Pedal PCB Forum members,
I have finished a nice clean build of the Ungula. Sadly it doesn't make much sound. It only passes sound through when I attack the string very hard, and it quickly disappears. Any sound it makes is way below unity volume, with the knobs dimed. I have reviewed the other forums with similar Ungula output problems, and I could change the A1M volume pot to a A100K, but I'm not sure if that will help change the minimal signal passing though?
I made some substitutions due to availability:
  1. -C14 spec 100uf I subd. 220uf
  2. -D3 & D4 spec 3mm red LED I subd. 3mm Green ( doubt that makes a diff?)
  3. -Q 2 & Q4 spec 2N1308 I subd. MPSA13
Please have a look at my pics, maybe you can catch an error outside of my Substitutions?
Is there a better option to sub 2N1308 with?
  • Ungula ( Hoof).pdf
