Jovi Bon Kenobi
Built another one! It's my favorite pedal on this site.
Mods: I wired it in stereo by running a wire from the ring lug of a stereo out jack to the input buffer solder point under the board. Along the wire's path is a 1uf MLCC and 1k resistor in series. The input buffer solder point is pin 1 of IC1, the TL072 in the bottom left. I have a TRS adapter breakout y-cable that allows the tip out to be wet and the ring out to be dry. It sounds glorious!
