Hi I'm looking to use multiple pcbs in one enclosure and only want 1 of the three controlled by a stomp with the other 2 using toggle switches.
Do I just leave the anode/ cathode and sw holes open on the pcb? And then wire up the dpdts like the photo attached? Are there any mods needed to doing a swap like this bc I know the resistor for the LEDs are usually built into the pcb so do I need to remove that as well??
Any guidance in doing some would be super appreciated! Also if anyone wants to share some multi pcb builds that'd also be awesome so I can have some inspiration/ frame of reference for my build!
cheers!
cheers!
