Coda
Go figure, I've built another BMP. This is my 7th Big Muff build (technically, its the 10th, since a few of them are modded to swtich between two different variants). I built this based on the V3 schematic on the Kit Rae site. I added a toggle that switches between stock V3 and the Zappa Mod (47k limiting resistors). In stock version, this is one of my favorite BMP sounds. Its a little chewy and chewy like a V4/5, has a nice low end that isnt too boomy like a Triangle, is clear and cuts well like a Ram's Head, and has a gritty growl that is reminiscent of a Sovtek. It even cleans up pretty good. Its interesting; at first it doesnt seem as gainy as any other muff, but this is misleading. What's interesting is the balance in the tone. The lower/bassier strings are bassy, thick, and a bit wooly...almost like a FF. The treble strings, however, are very clear, creamy, with a lot of sustain. The tone is also very harmonically rich. Its a very focused, spongy tone (adjectives, lol)...
The Zappa mod is interesting too. The toggles swaps in 47k limiting resistors. I'll explain further, for those in the back of the room: the limiting resistors limit the signal going in to each gain stage. The higher the resistors, the lower the gain. Normally, a BMP with have limiting resistor values of either 8k, 10k, or 12k, depending on whatever they had on hand that day. 47k limiting resistors are limiting a fair amount gain. With the Sustain control maxed (which is full CCW on this one, I confused myself with the wiring) the pedal is comparable to an average BMP with its control at about 10-11 o'clock. However, you still have a fair amount of sustain. So its a smoother, more mellow tone, that sustains like a BMP. It's also a bit quiet and dark, so you have to adjust volume and tone when you switch it. It really shines with a distortion/boost running into it. In fact, with Zappa mod on, a DS-1 running into it, and a little bit of chorus, you can really nail those crazier 1980's Zappa tones...you know...the ones where he would sit on a stool the whole song, drinking coffee, and then pick up his guitar, melt face, and then put it down and start reading a magazine...
TL/DR: BMP=good, V3 BMP= gooder, V3 BMP with Zappa mods= goodest. Do yourself a favor, the next time the pedal goblin (Fig) whispers in your ear "build another pedal," do yourself a favor and build a non-common BMP...
A quick word on my artwork: I don't do artwork. While I am artistically rich musically, and with creating stories and jokes and interpretive dance, my visual art skills are pretty sad...
