matt3310
I built the pedal and it sounds good. Only problem im having is with the gain. If I keep it super low (under 1) its fine. The gain seems to max out at 1 and doesn't change any more as I turn up the knob. and ti turn the gain down is almost impossible as you have so little room for adjustment. The pot in place is a A250. Should I go with a lower value pot?
