I put together a Van Pelt that went together pretty well. When I plugged it in and compared it to the Angry Charles (Angry Charlie V3), it seemed quiet. It is more quiet than clean signal until you turn the volume up to 65% or so.
Here is what I have tried:
The Bridgold BS170 BS170 values, in VDC, are:
Q1D: 5.43
Q1G: 2.70
Q1S: 2.92
Q2D: 4.66
Q2G: 2.33
Q2S: 0.13
Q3D: 4.85
Q3G: 2.43
Q3S: 0.22
What's suspect to me is that the source on Q1 is higher than the others which is why I replaced the 9.1V diode.
Pretty stumped as to what it could be. Any advice or suggestions would be appreciated.
Thank you in advance.
- Double checked my component values.
- Checked for loose solder joints and hit each pad with the soldering iron to make sure no dry joints.
- Double checked the footswitch connections and resoldered those.
- I checked the signal path with the probe for any drops along the way and it all sounded good.
- I replaced the BS170s as maybe they were bad or were damaged by static electricity. Same result.
- Replaced the 9.1V diode
- Replaced the R25 100K resistor
- Replaced the Volume A100K potentiometer
Q1D: 5.43
Q1G: 2.70
Q1S: 2.92
Q2D: 4.66
Q2G: 2.33
Q2S: 0.13
Q3D: 4.85
Q3G: 2.43
Q3S: 0.22
