Yep, contacted them and they said that the MOQ would be 128 for a pot. And I'm not sure they have a US based distributor.Vimex anything is going to be good, they only sell commercial manufacturing grade parts in bigger quantities. Not easily available to hobbyists most of the time. I wouldn’t worry!
No need to drill a small hole for the Alpha pots. Just use pliers to break off the tab from the pot.What I like about Vimex pots is that they don't require drilling extra small hole.
I'm wondering if there are other distributors apart from Pedal Parts Australia who store them?
That's a common practice which I don't like, because the tab is not supposed to be cut.No need to drill a small hole for the Alpha pots. Just use pliers to break off the tab from the pot.
I have never seen anything to suggest that is the case,. It certainly does not hurt the integrity of the pot.That's a common practice which I don't like, because the tab is not supposed to be cut.
Not at all. I just don't understand why Alpha does not manufacture 16mm potentiometers without this tab.I have never seen anything to suggest that is the case,. It certainly does not hurt the integrity of the pot.
Ahhh ---- there's the optional use case for the peg!Those giant rotosound-style enclosures come pre-drilled w the extra orientation hole, the idea of actually using it ticks a very particular Virgo box for me.
