andare
Hi, I'm building PNP germanium fuzzes and I need a voltage inverter board. Since I know nothing I'm not sure which of the following layouts work for adding a 1N5817 diode for polarity protection. #2 is the most convenient because the diode lays flat and the board isn't big. There is a trace cut under the diode of course.
Also, do the caps need to be 10uF and 47uF or can they both be 10uF? Thanks!
