I am working on my third pedal from here! It's a Blue Shu Gai (PG-14). I boxed it up and noticed that when the volume is turned all the way up I get no sound. When I slowly turn the volume pot down it reaches a point (around 30% volume) all the sudden the signal cuts in. When I turn it down more the volume cuts again. Basically I can play the effect if I don't turn the volume knob past a certain range.
Has anyone experienced this before? It lights up fine, and passes normal signal in bypass mode. Should I replace the volume pot?
