Walrus Audio SLO (reverb)
Kroars
I’d love to see this offered on a PedalPCB board. Not sure how easy the algorithms would be to obtain, but it’s worth a shot to ask :)
Upvote 25
By Godot, Kroars, this deserves an upvote. You're one of the few to put any additional effort into demonstrating why something should be reconstituted by PPCB.
Thank you.
Hmm, maybe if this comes to fruition, I could add a Soldanao SLO circuit to it ... a SLO + SLÖ, and call it the SLOth. HMm, nevermind.
Getting the algorithms is simple, but we can't use them.... I don't touch proprietary code.
We can come up with something functionally similar though.
I see. Thanks for clearing that up, I wasn’t sure how that worked.
Curious about how you'd get them. Dump the flash memory or something? I get why you can't use them, but I'm interested in the technical details in acquiring the algorithm. I'm familiar with dumping firmware on embedded devices and I wonder if this is similar.
Not to be overly critical but out side of the dream mode I found the Slo to be a little underwhelming. Dark mode is a sub octave reverb that to me was hard to make super useful, rise is a gated swell reverb that works pretty good unless you are running in an effects loop. The modulation was really strong if dialed in too much so I think it could be paired back quite a bit to make it useable. Dream mode sounded excellent and the freeze effect is nice.
Just my thoughts not trying to be a downer
Not at all! That’s why this forum is great! The reality is, I don’t know much about it at all, just saw a couple clips. I certainly appreciate your perspective, perhaps it’s not one that needs to be on my immediate radar. :)
Yeah. Programs for FV-1 are typically stored on an EEPROM (although I seem to remember a project somewhere that used an Arduino to emulate the EEPROM).
Something like this would do it: https://www.amazon.com/KeeYees-SOIC...words=ch341a+programmer&qid=1676333416&sr=8-3
That Dark Mode sub-octave would be fun to play around with for the bass players. Maybe.
I'm interested in it just for the freeze effect. Other effects would be icing...
Also, I did not see ADAOCE's post as downer, but rather as additional perspective on this effect. Always happy to see things from another's perspective — informed and enriched is good.
Interesting. I have a Slötva (SLO with presets) and have found the Rise to be hard to use. However, I have it in the effects loop and you imply that this is a problem. Why is that?
My amp doesn't have an effects loop, so I can't speak from experience but they mention in the manual that Rise mode works best in front of an amp. My guess would be that it has something to do with the way the signal hits the pedal differently between the two? I've found Rise mode to be a little finicky as well, but when it's dialed in right it's pretty cool. I think having the "X" knob set to like noon or less makes it easier to get cool sounds out of.
I did some research last night and according to a bunch of folks, the signal in the effects loop is not generally high enough to trigger the gate of the effect. ( in the Rise mode it is effectively like a noise gate)
This tracks with my experience. If I turn up the volume of ANY pedal the Rise kicks in.
Some folks recommended sticking a boost in the effects loop.
Seems to me that the Slö would work pretty well before the effects loop, but I haven't tried it yet.
So to simplify it for dummies such as myself, are you saying you would take this device, clip it into the EEPROM in an FV-1-based pedal, the other end to a blank EEPROM, transfer (i.e. steal), and then you'd use that copied EEPROM in a PCB with the same circuit/control layout? Would it function in the Pythagoras/Arachnid (of course the controls wouldn't necessarily correlate)?
Digital is indistinguishable from magic to me.
More or less. You’d need to copy the EEPROM to a computer. Then disconnect that device from the pedal and connect it to a blank EEPROM and use your computer to program it.
** I am not a lawyer, but software is generally protected under copyright and licensing rules, so this would likely be illegal. **
No telling if it would work in a Pythagoras or not verbatim. Often they require custom circuits. For example, I believe the feedback path of the ARP-87 is analog.
Yes the Slo works outside of the effects loop or with a boost in the loop just fine but in the loop by itself it rarely triggered
To be fair to this pedal if I had more disposable income towards commercial pedals I probably would have kept it but such is life hah!
Sorry just saw your quote of my post now. Your research is spot on it’s gating the incoming signal to trigger the sweep effect and if it’s too low or just doesn’t trigger like it should
It's best to remove the EEPROM from the PCB before connecting it to an EEPROM programmer.
Most EEPROM programmers run at 5V, the FV-1 IC runs at 3.3V. If you clip the device onto the EEPROM in-circuit it'll hit the FV-1 with overvoltage.
Not actually going to attempt this, but just trying to wrap my mind around the process. So technically it's pretty easy to rip off someone's code, as Mooer did to EHX with their POG clone.
