uranium_jones
Hi everyone. Long time, no see. But I have only now got my soldering bench back in place after more than 6 months of medical and construction hell.
I'mma cut to the chase: I need to make an ultrasonic white noise speaker system, omnidirectional as can be and with a frequency range of maybe 12-15 kHz on the low end, and sky's the limit on the high end. This will be to excite an interior space only with broadband high-frequency content The joys of working in a scientific field!
I have come here because I don't know of any better collection of electrical-engineering-and-audio-adjacent people on the internet.
So here's what I have so far:
1) https://circuitdigest.com/electronic-circuits/simple-white-noise-generator-circuit-diagram - This seems like a simple way to get some white noise going, although I don't like the requirement for so much voltage on the power supply. 9-18V would be better. Maybe there's a way I could use some sort of charge pump? But I don't know about that. Anyway, I figure a simple high-pass filter should cut frequencies below... let's say 14 kHz because I think that's how high I can hear, and I don't want this to get annoying.
2) These piezo drivers seem like they will do the trick: https://www.amazon.com/gp/product/B08SLZBKCH/ - Maybe I need to order 4 to shoot sound in 4 directions and be pseudo-omnidirectional? Radiating in a hemisphere would do fine.
3) It's tricky to try and find cheap amplifiers that will definitely go above 20kHz. This one seems to do it though: https://www.amazon.com/gp/product/B0087318VC/ - I don't need a flat frequency response above 20 kHz, but I don't want someone to have put in a lowpass filter.
Wish List:
- a protoboard circuit design that will give me everything I need in one circuit: connection to a DC power supply jack, the white noise generation circuit, an on/off switch, a volume pot, connection to the amplifier, power and signal lines to the amplifier (Can I run the white noise source and the amp on the same PSU?)
- general purpose recommendations on things to watch out for.
Sorry that this is entirely out of left field, but it's good to be back on the forum.
Wish List:
