Wiring four Arachnid Multi FXs in parallel.
Pauleo1214
A month back, I bought four of these boards with the intention of wiring them in parallel to create the ultimate, ambient noise machine. I alas am not as technically savvy as I should be and wanted to know the best way to go about doing this.
My initial plan is to use four GPCB Buff N' Blends (one for each Arachnid being wired to the send/return loop). That said, I still wonder how this setup would reconcile with the mix control on the Arachnid itself. If all Arachnids are wired to Buff N' Blends, would the mix control still blend only the dry signal? Theoretically, I believe if I wire the Buff N' Blends according to their build sheets with the A100K blend pots, I think it should work as individual mixer knobs for each of the four respective boards.
I would greatly appreciate someone with expertise to confirm whether this would work.
Best,
Paul
I think you are correct, but I also think you probably don’t need the BnB mix knob, or even 4 of them. You need an input and an output buffers so that you can split the signal to the 4 circuits without worrying about load.
Thank you Giovanni. To re-frame what you are saying, a single Buff n' Blend could be used with four leads going from the send pad to each of the four arachnids
As for the mix knob, I think a pot or a 50k resistor is needed to balance the levels of the dry signal with the wet signals of the Arachnids.
Looks like I'll have no choice but dive head first! I'll obviously do a preliminary test before throwing it all into an enclosure!
Just ordered the EEPROMS. Each one has all 6 delay algorithms with 2 other algorithms to mix things up.
