Haven't considered using the relay bypass module for a build - just re-read the description on the shop's site. What other pedals would you all consider popping one of those modules in? That thing has some pretty sweet creative applications the more I think about it.
Nice idea utilizing it for the Woodpecker!
Pretty much this. Also, It'd be cool on a reverb if it had trails but I don't think any PCBs do that here.I like to consider relay switching for anything that isn't "always on" for me (e.g., a compressor—although some folks use compressors as an 'effect' and don't have it always on) or something that I might want to use momentarily. Mostly, time-based or modulation effects are good candidates. They can be good for distortion/OD, too. You just have to weigh the pros/cons and consider how you use things. A SPST switch has better longevity and smoother actuation and you have a momentary option. But there are more parts, it's a bigger footprint, some relay switching circuits have a brief muting period to avoid switching noise, and it's an overall more expensive switching option.
Madbeanpedals just started offering several different bypass boards, including one with a "short fade": http://www.madbeanpedals.com/projects/_folders/Bypass/pdf/3PDT-03.pdfPretty much this. Also, It'd be cool on a reverb if it had trails but I don't think any PCBs do that here.
That's for the LED. Signal trails involve a bit more circuitry and cannot be true bypass.Madbeanpedals just started offering several different bypass boards, including one with a "short fade": http://www.madbeanpedals.com/projects/_folders/Bypass/pdf/3PDT-03.pdf
It uses a capacitor to make the fade, so it would not have long-trails. Might be fun to experiments with.
Haha, no worries! That would be a cool option though.Wow. I completely misunderstood what that was supposed to do. And obviously did not stop to read the description closely.
Which P Touch do you use? Does it do all the design labels?I've got The Chops! Here it is. It was a quick and easy build and it sounds exactly like my Hummingbird. Tayda red enclosure. LMS knobs. P-Touch printed labels. Relay bypass module for that sweet soft touch and momentary usage.
An older ptd600. I use the software that you have to download for your computer and connect it via USB cable. Basically, I can print any image or font from whatever's on my computer screen. The stock fonts that it comes with straight from the machine are much simpler and IMO kinda boring. I find a cool font on the internet, test it with what I want it to say, snap an image of it, then print it on my P-Touch.Which P Touch do you use? Does it do all the design labels?
Do you use it with a clear background?The ptd600. I use the software that you have to download for your computer and connect it via USB cable. Basically, any image or font I can print from my computer. The stock fonts that it comes with are much simpler. I find a cool font on the internet, test it with what I want it to say, snap an image of it, then print it on my P-Touch.
Yeah, I buy off brand clear tape labels with different colored letters. 12mm or 18mm size. I've seen em in black, white, gold, blue, and red (on clear tape).Do you use it with a clear background?
Here are the white on clear I useAwesome I might give it a try, where so you buy your clear labels?
