SleezyLobster
I've been working on the Caesar Chorus as my first build since I'd tried to make something easier but left out a capacitor and a pot in my order so I transitioned to this one. So my first mistake was that my 5mm LEDs were in backwards and I fixed that so now my internal 3mm LEDs and my 5mm LEDs all work and flash with the rate knob, and when I turn the pedal off I can get sound through even though there is a little hum. However, when I turn on the pedal the hum gets slightly worse and I get no signal. I tried checking continuity throughout and I would get beeps but sometimes it would only be on one of the legs of components and not the other but further down the signal path it would still be working so I'm not sure if that's a problem. I've also built an audio probe but when I plug it in I get a really bad hum that gets worse when I touch components. It used to go away when I'd touch the tip of the input jack but now even that hums and all I changed was the LEDs. When it would be quiet, I could only get to the first capacitor before it would just buzz regardless of whether or not I was touching the leads, and the solder joints seemed fine for it but I also don't really know how to use a DMM or the audio probe. Also while I was soldering I kept having problems with the solder sticking to the iron and not wanting to flow onto the pad. It only happened to a few of the pads and when I tried to increase temp, add more flux, and reflow it it still would do it only for those pads. That's why some of them look so messed up but I'm hoping they still have a solid connection. I've messed with all the pots including the trim and there was nothing. Does anyone see any apparent issues or know what I'm doing wrong while audio probing? Also my DMM is a UNI-T UT133B and it doesn't have a frequency thing like I've heard someone suggest before.
