mzy12
Hello!
I am building a Devi Ever Ruby on stripboard and I want to be able to change from standard 9V input to 6V via a 78L06 with the flick of switch. It should be pretty simple, just have the power strip attached to a switch and flick between the 9V coming from the filter caps and 6V from the regulator. Are there any steps I should take to make sure the transition is as seamless as possible? I will be supplying the 78L06 with 9V constantly and just take the output from an SPDT when I need it. Should I do something like make sure it is provided with a load at all times?
Thanks in advance!
Thanks in advance!
