andare
Finished this build and it's perfect but I noticed a faint ticking in bypass when in Chorus mode. I made sure none of the wires are close to any of the ICs. I don't have good shielded wire. The one I have has thin wire surrounded by thick, stiff insulation and it breaks at the solder joints every single time.
I noticed the build docs and the builds I found here don't ground the board input on bypass by I decided to do it to avoid pops. I don't think this has an effect on the output?
Things I tried:
I would also like to disable the always-on vibrato rate LED which drives me insane. How can I do that safely?
Thanks
Things I tried:
- tucking wires as far as possible from any ICs didn't help
- grounding board output in bypass with an alligator clip created oscillation
Thanks
