JTEX
This code uses momentary, SPST, normally-open pushbuttons (or stompswitches) to toggle On/Off some dual coil latching relays. I'm not a seasoned Arduino programmer by any stretch, so it took me quite a while to come up with it. Especially since I had to figure out a way to cut down on power as much as possible, for battery operation, so I had to use sleep mode and hardware interrupts when buttons are pressed. First time using either...
Hope it helps someone. Do whatever you want with it.
C:
// ****** 3 momentary pushbuttons (tactile switches) toggle 3 dual coil DPDT latching relays (push on/push off) ******
// Coded by Jerry Catanescu (jtex.ca)
// VERSION 0.1, 2022-12-28
// Works with Digispark Pro (ATtiny167 Pro). Optimised for minimal power use
// (go to sleep mode whenever idle, use interrupts to wake up only when a button is pressed)
// I used Kemet EA2-5TNJ dual coil latching relays. A 5V-powered ATtiny167/87 can drive them directly. Not even discrete flyback diodes are needed.
// The momentary pushbuttons are NO (normally open).
// One pin of every pushbutton, as well as the negative pins of all relay coils, are connected to ground.
#include <avr/power.h>
#include <avr/sleep.h>
#include <avr/interrupt.h>
const byte rly_setpin[3] = { 6, 8, 10 }; // relay +SET pins
const byte rly_rstpin[3] = { 7, 9, 11 }; // relay +RESET pins
const byte btn_pin[3] = { 0, 1, 2 }; // pushbutton pins (note: there's an LED on pin 1 Digispark Pro. I removed it. You can leave it alone and use another pin if you prefer.)
bool rly_state[3] = { 0, 0, 0 }; // array containing the current relay states: 0 = RESET, 1 = SET
// setup() runs only once when program starts:
void setup() {
for (byte i = 0; i < 12; i++) {
pinMode(i, INPUT_PULLUP); // initially set all pins to INPUT_PULLUP, which reduces current draw
// iterate through all relays, set up their pins and initialize
for (byte i = 0; i < 3; i++) {
pinMode(rly_setpin[i], OUTPUT); // configure all SET coil pins as OUTPUT
pinMode(rly_rstpin[i], OUTPUT); // configure all RESET coil pins as OUTPUT
digitalWrite(rly_setpin[i], 0); // initialize SET pins to 0
digitalWrite(rly_rstpin[i], 1);
delay(10);
digitalWrite(rly_rstpin[i], 0); // send pulse to latch the relays in the RESET state
// Turn off unused ATtiny167 subsystems to save power
power_adc_disable(); // Analog to Digital Converter
power_lin_disable(); // LIN module
power_spi_disable(); // Serial Peripheral Interface
power_usi_disable(); // Universal Serial Interface
power_timer1_disable();
// Pin Change Mask Register 1. Applies to Port B pins (PB0, 1...). See ATtiny167 datasheet
PCMSK1 = 0b00000111; // Turn on interrupt triggering for the specified pin(s) (logic 1)
// Pin Change Interrupt Control Register. See ATtiny167 datasheet.
PCICR = 0b00000010; // Second bit from the right is the Port B bank.
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
// Interrupt handler fires whenever there is a logic change on the designated Port B interrupt pin(s) (where the pushbuttons are wired)
ISR(PCINT1_vect) {
delayMicroseconds(5000); // just wait a bit to avoid firing multiple times due to bouncy button
// then we simply exit and return control to the main loop()
// latch relays in the SET or RESET state
void latchRelay() {
noInterrupts(); // disable interrupts, to ignore any button activity (glitches, double-presses etc) that may happen until we're done latching the relay (debounce)
bool btnLastState[3] = { HIGH, HIGH, HIGH }; // for starters, initialize all button states as "up" (logic HIGH)
do {
if (digitalRead(btn_pin[i]) == LOW) { // if this button # was pushed
// delayMicroseconds() works even while the interrupts are turned off, unlike delay()
delayMicroseconds(3000); // wait a bit to account for bouncy contacts.
if (digitalRead(btn_pin[i]) == LOW) { // read button again after a delay, to insure it's still down (no glitches)
delayMicroseconds(2000);
if (digitalRead(btn_pin[i]) == LOW) { // read button state the 3rd time. If it's still low, we accept it as stable
if (btnLastState[i] == HIGH) {
rly_state[i] = !rly_state[i]; // toggle the relay state
btnLastState[i] = LOW; // record the fact that the button was pressed
if (rly_state[i]) { // if the relay should be latched to the SET state
digitalWrite(rly_setpin[i], 1);
delayMicroseconds(5000); // Hold the logic "1" long enough to latch the relay. 10ms shoud do it.
} else { // if the relay should be RESET
} else { // if this button # wasn't pushed
btnLastState[i] = HIGH;
// optional: do something if all 3 buttons are pressed simulaneously
if (!digitalRead(btn_pin[0]) && !digitalRead(btn_pin[1]) && !digitalRead(btn_pin[2])) { // all three buttons pressed
// do something awesome, maybe? Such as, true bypass? TBD.
} else {
// placeholder
} while (!digitalRead(btn_pin[0]) || !digitalRead(btn_pin[1]) || !digitalRead(btn_pin[2])); // stay in this loop as long as at least one button is pressed
interrupts(); // re-enable interrupts before exiting function
///////////////////////// MAIN PROGRAM LOOP ///////////////////////////////////
void loop() {
sleep_cpu(); // Sleep all the time except when woken by an interrupt (meaning that a button was pressed)
latchRelay(); // If we ever get here, we got kicked out of sleep by a button press, so we need to handle the relays
