Lytt Effects
Ok, quick question. I have a 3PDT breakout board that has the on-board buffer on/off switch found here. First question: is this compatible with the Informant (1981 DRV) pcb, and second: do the grounds from the jacks go to the ground pads on the breakout board, or do the grounds from the in/out jacks still need to go to the main pcb?
Thanks in advance for answering this extremely novice question.
