I also soldered a ground wire to connect all three pots together tooAll pots should go to ground indeed, otherwise your tone pots won’t work either.
And that goes to the ground of the output jack right? Just checkin.I also soldered a ground wire to connect all three pots together too
Do you have a simple Alpha 250kA pot to see if the wiring works then?Thats whats driving me crazy... yeah the jack ground is connected to lug three of the volume pot... tone knobs work... I just ordered new pots and a new switch again.. they starting to look ratty after rewiring a couple times... so im gonna start over fresh
It's a bummer that you had to order new ones. When you get it wired up again, hopefully all is well! If not, snap some pics in case somebody spots something that was missed.I just ordered new pots and a new switch again
