mkstewartesq
Thanks for the heads-up. I snagged some in case it disappears again.
How do you guys store the glue in a bag after the first use?
![IMG_0398.jpeg IMG_0398.jpeg](https://forum.pedalpcb.com/data/attachments/63/63894-db27594e90fe7311d32f9035fa6e6f64.jpg)
Small bottle I bought at Walmart.
Mike
I poured mine in a dropper bottle. It's handy anyways to put a few drops on the enclosure and then spread the glue around with a brush.Thanks for the heads-up. I snagged some in case it disappears again.
I plan to try it for the first time today!I am getting my first ever sunnyscopa today. I’m excited to try it out!
Thank you for the tip!Hey, just a possible word of caution. The last batch of film free decal I got, the glue seemed to cure much more quickly than before (meaning that it was much harder to peel off the film off and clean the excess glue after the initial curing then usual). Similarly, when I did the second bake to really cure the decal, baking it for my normal length of time (30 minutes at 230°) seemed to overcook it. Maybe it was just a bad batch of glue - but the event, be careful about over-curing. At least for this batch, I am going to cut my curing time for both the initial and the final cure in half just to be safe - so now I’ll do 5 minutes for the initial cure and 15 for the final cure.
Mike
Hey, just a possible word of caution. The last batch of film free decal I got, the glue seemed to cure much more quickly than before (meaning that it was much harder to peel off the film off and clean the excess glue after the initial curing than usual).
Is your first cure with a heat gun? Or in the oven?
Could it be that you got a bad batch of gllue?Let’s just say today was a bit fraught. Still something different about this glue mixture. I applied the decal and cooked it for the first bake for half the time at 230° (six minutes. The film came off but the ink did not adhere in spots. So I used some acetone and rubbing alcohol to weaken it and pretty much scraped off the original decal.
Then I applied the decal a second time and baked did it slightly lower temperature (225°) but let it bake for just one minute longer (seven minutes) since the temperature was lower. This time the decal film was an unholy bitch to get off (it finally came off in pieces) but at least the image is 99% there so I’m going to call it a day on this one.
Since I normally apply a coat of clearcoat, I’m not even sure if I’m going to do a second bake on this for a final cure – last time I did that, the decal actually looked worse after the final cure than it did after the initial cure.
Mike
Either that or they've changed their formulation.Could it be that you got a bad batch of gllue?
In the end it turned out pretty damn goodLet’s just say today was a bit fraught. Still something different about this glue mixture. I applied the decal and cooked it for the first bake for half the time at 230° (six minutes. The film came off but the ink did not adhere in spots. So I used some acetone and rubbing alcohol to weaken it and pretty much scraped off the original decal.
Mike
Do you coat the size of the enclosure as well as the face?Thank you!
I use this – I buy it at Walmart. I can’t say I have any specific reason for preferring it over any other brand – I just picked it up once and it worked well so I stuck with it.
Mike
