Chuck D. Bones
Circuit Wizard
Vgs,off is the gate voltage necessary to drive the drain current to zero. Since it is not possible to measure zero amps, the datasheet specifies a very small drain current, usually 10nA or 100nA, although I have seen Vgs,off spec'ed at Id = 1uA in one datasheet.
Vgs,off and Idss define the limits of JFET operation. The drain current can never be less than 0 or higher than Idss. It's just not physically possible.
Vgs = Vgs,off when Id = 0 and Vgs = 0 when Id = Idss.. Vgs can be more negative than Vgs,off or more positive than 0, but nothing useful happens when Vgs is outside the range from 0 to Vgs,off.
I did not use the most accurate method for measuring Vgs,off. I used the easiest method. I'm exploring a more accurate method and will revisit the data I published at the top of this thread.
