This Week on the Breadboard: The EHX Ripped Speaker
Chuck D. Bones
Circuit Wizard
With some mods, of course. Here's the stock circuit:
I could do without the opamps. I tossed the input buffer and replaced the active Tone circuit with a BMP-style Tone circuit followed by a MOSFET buffer. Gets the job done with a lot fewer parts. I've tried the active Tone circuit with other things and while it's clever, it has limitations. I redid the FUZZ control, tweaked a few component values and here we are. I tried Ge for Q3, but ended up liking Si better. I used a BC109C for Q1 on the breadboard. This baby has plenty of gain, over 80dB. The RIP pot varies the bias on Q3 from cutoff to saturated. Gating can be splatty, mild, or fully open. There's no clean setting unless we back the guitar's volume knob down a ways. Definitely some vintage fuzz tones in there.
Knobs (L-R): LEVEL - TONE - RIP - FUZZ
Q4 on thr far left, Q1 on the far right.
No, it's simply an optional unity gain buffer. I considered a boost stage, but the signal is plenty large without a boost.
To delete the buffer, remove R16-R20, C8-C9 & Q4. Pin 2 of the LEVEL pot is the output.
So leave it in there & it will work anywhere in the chain.
It a touchy subject as I read years go about Lovepedal & MXR not gelling with other pedals because of impedance issues.
Those are some interesting transistor footprints.
Why even bother with SMD pads for parts that are so easy to get in thru-hole? Q2 & Q3 can be pretty much whatever you want.
You must have missed the single footprint on the Skull Valley.
I checked to see if sheep had 3 toes!:D
It's good that the pinout is labelled.
It's one transistor footprint to rule them all (Lord of the Footprints). The worst case is a bit of twister with some weird pin-outs on TH. Before, I'd have to have different footprints for EBC, CBE, DGS, DSG.. and even those would cause confusion at times. Now, it's just one with different labels for JFET vs BJT.
It covers SMD and TH and I think it's pretty clear which pad is what. I default to SMD transistors where I can. They're cheaper, and there are a few SMD-only options out there which are interesting.
