debrad
A friend of mine has asked if I can build him a Hyped Fuzz with a "Blend" or "Mixing" knob instead of the 3 way Mode toggle.
In my research, I came across a post from @Grubb (Hyped Fuzz Mode Blend) who was trying to do the same thing but didn't receive any answers to his questions so I will ask again with the hope that someone more knowledgeable than I will chime in with some words of wisdom (or maybe @Grubb ploughed ahead and can share the results...):
1) Can I replace the 3 way toggle with a potentiometer which would give me Fuzz 1 at one end of the rotation, Fuzz 2 at the other end, and a blend of the two in between (I realize that I may lose the boost function, he's OK with that, but I am also thinking that I could use a switch to toggle between the blended fuzz path and the boost path if he wants...).
2) Would it work to install the potentiometer where @Grubb suggested below (Scooped path goes from R26 to one outside lug of a pot, Full path goes from R27 to the other outside lug of a pot, and lug 2 connects to R28)?
3) What would be an appropriate resistance for the blend/mix potentiometer...something small (under 50k to minimize the impact on the values of R26 and R27), something between 100k and 500k, or something larger?
