I've stuck caps on an sig gen and scope, then bode plotted the human range and I didn't find any difference between Panasonic and Wima. Yet the sound difference between them as a cap between a solid state amp pre and power sections was marked. As too vs the old electrolytic that had been fried for 25 years..
I can see we're headed towards the cap grave yard conversation.. In the end if the cap is leaky, dried out and in circuit it's going to sound ... not the best irrespective of type.
Many components sound better due to interactions outside of our hearing range. Oscillations, positive/negative feedback and noise can suck power and distort the AC waveform, even if there's MHz noise riding over the top of audio. Same as a bad clock or digital signal causes jitter etc.
However if you use toilet roll, paint it like big caps, give it silver wire leads and put it in the marketing blurb, then suddenly it becomes a thing.
I've bode tested the caps, then experimentally tested it some more, and if it makes a difference then so be it.. the best price works for me - even if that's cheap. In the end the WIMA/Vishay/Nichicon are less "audio" and more reliably built that deliver close performance in every cap.. when you have high voltages you don't want to be the person that experiences the bad day cap. I will pay a little more for that.
