Hi all. I am on my second try at building the Emu Amp Sim. I may have overreacted with my first build, but as it was coming together it did not seem like the switches were mounted correctly. It didn’t feel like they were high enough to protrude far enough above the base plate to access.Anyway, before I solder in on round 2, I wanted to make sure I wasn’t missing anything obvious. I’ve attached a picture of the rough in. Is this how to mount the switches, or am I supposed to life the breakout board up on the header pins a bit so they sit higher?
Appreciate any advice!
