Terrarium Rev 1 with Daisy Seed v1.2 rev 7 Noise Issue Work Around - Applies to OLD Terrarium REV 1 board only!
Actually i think the issue may have something to do with my cheap power supply. The two other pedals ive built ive tested with higher quality power adapters so maybe thats it
Just wanted to post a very late thanks to @keyth72 for the fix here as it was driving me a little crazy. Also thanks for the GuitarML github repo as I'm learning a lot from it! I basically did exactly as in the photos and it works great.
You're welcome, but I don't think you actually needed to do that, you have a "Rev 2" Terrarium board which should include the low pass filter already. Did you try it without the additional breakout board first? I don't think the extra low pass filter will hurt it, it's just redunant.
I need to make that clear in this post, maybe I can edit the title to say Rev1 Terrarium only. I recently built the rev 2 board and it worked great with no noise on it's own. Glad you're finding the github stuff useful!
