Holy Island's "HOW TO BUILD A SPEED MODDED TAPE PLAYER" help?
Martial Sound
In the video it's all pretty straight forward as far as wiring goes but I have 2 questions.
  1. what's the process of adding the LM317 for the power conversion and...
  2. adding the delay/PT2399 circuit into this. I actually have a shite Donner/Amazon delay pedal with that chip and I think I could just wire it into this but I'm lost on how and where it would go in placement AND if the 9v wall wart power will power the tape player and delay sufficiently? I'm sure it will but just curious.
I dont think Mr. Holy Island likes to provide much support with these things as I'm sure he's bogged down with them but any help for a fellow tinkerer would be greatly appreciated!
Thanks in advance!
1.)
The diagram from the video shows 240 and 390R.
Calculator confirms this should get you to 3.3-ish V out.
You just build the little circuit he drew on a piece of perf or protoboard, and wire it in series 9V supply > LM317 board > Power In on cassette player (per his photo)
2.) What he has labeled Out (yellow wire) on that photo diagram would just go to the audio In jack of your pedal (or straight to the Audio In on the pedal’s PCB, if you’re going to unbox it and make a shared enclosure like in the video). Then the pedal’s Out is audio out for the whole deal.
You should be able to run these both off a shared 9V supply as long as it has enough mA available for both. You just split it at the DC In jack: 9V wire straight to pedal, other 9V wire > 3.3V board > cassette player.
This looks like a fun project, and I think I just found this identical cassette player on Amazon for $20! May have to give this one a try;)
1.)
Thank you SO MUCH. Yeah he mentions getting those on Amazon for $20. Seems very fun just dont want to fuck up the power AND adding the delay circuit. I love low-fi sounds like this. Thank you again!
1.)
In the schematic he has 2 capacitors on the board as well. that's where some confusion came as well as LM117 and LM317 in series
LM117 and LM317 are the same, 117 just has a wider temperature range (and thus will probably be more expensive if you find one). 317 is fine here, and you only need one regulator.
If you look at the datasheet for any voltage regulator, they always show caps in those spots. I assume they’re for cleaning up the power in some way, filtering out stray AC or noise maybe 🤷‍♀️
At any rate they’re a standard component when using a voltage regulator.
Thank you so much for this. Really cleared everything up!
