Twin Face Fuzz external trim pot bias knobs
Drlufk00
If I was to add external bias trim knobs is it safe to assume that the pads circled in the attached photo would all correlate to lug 1 on a standard B10K alpha pot? I only ask because the trim pots on this PCB seem to be turned 180 degrees compared to the Silismile Fuzz I built previously.
3362P Datasheet
I think that this is pin 3 on the bourns trimmer, at least if it's mounted on the same side as all the other components, but it really doesn't matter in this circuit, since trimpot is really just used as a variable resistor with Pin 1 and 2 tied together.
