Opening: mary-halvorson-02.spcd.
java.io.InvalidClassException: javax.swing.JComponent; local class incompatible: stream classdesc serialVersionUID = 4588530037560142483, local class serialVersionUID = 3742318830738515599
at java.i
bjectStreamClass.initNonProxy(ObjectStreamClass.java:699)
at java.i
bjectInputStream.readNonProxyDesc(ObjectInputStream.java:2046)
at java.i
bjectInputStream.readClassDesc(ObjectInputStream.java:1893)
at java.i
at java.i
at java.i
bjectInputStream.readOrdinaryObject(ObjectInputStream.java:2227)
at java.i
bjectInputStream.readObject0(ObjectInputStream.java:1710)
at java.i
bjectInputStream.defaultReadFields(ObjectInputStream.java:2472)
at java.i
bjectInputStream.readSerialData(ObjectInputStream.java:2396)
at java.i
bjectInputStream.readOrdinaryObject(ObjectInputStream.java:2254)
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
bjectInputStream.readObject(ObjectInputStream.java:508)
at java.i
bjectInputStream.readObject(ObjectInputStream.java:466)
at java.util.ArrayList.readObject(ArrayList.java:799)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at java.i
bjectStreamClass.invokeReadObject(ObjectStreamClass.java:1185
at java.i
bjectInputStream.readSerialData(ObjectInputStream.java:2363)
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at com.holycityaudio.SpinCAD.SpinCADFile.fileReadPatch(SpinCADFile.java:156)
at com.holycityaudio.SpinCAD.SpinCADFile.fileOpenPatch(SpinCADFile.java:303)
at com.holycityaudio.SpinCAD.SpinCADFrame$3.actionPerformed(SpinCADFrame.java:294)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:828)
at com.apple.laf.AquaMenuItemUI.doClick(AquaMenuItemUI.java:157)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:872)
at java.awt.Component.processMouseEvent(Component.java:6539)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3318)
at java.awt.Component.processEvent(Component.java:6304)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
at java.awt.Container.dispatchEventImpl(Container.java:2283)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Trying version 952 format...
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
bjectStreamClass.invokeReadObject(ObjectStreamClass.java:1185)
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at java.i
at com.holycityaudio.SpinCAD.SpinCADFile.fileReadPatch952(SpinCADFile.java:171)
at com.holycityaudio.SpinCAD.SpinCADFile.fileOpenPatch(SpinCADFile.java:308)
Code: 0
EditResources toolbar Action Event
