Adding Parallel Out to Empyrean Deluxe
gtfields13
I am building the Empyrean Deluxe from AionFX for someone else, and they wanted to have the XLR and parallel output from the original. The parallel out isn't shown on the tracing journal for the Darkglass Alpha Omega (or I am getting lost in the spaghetti). Is it really as simple as just running jumper wire from the input jack over to the parallel output, or should I take a signal from the first input buffer so that it can drive whatever comes next? I definitely could take some guidance from more experienced modders.
Thanks!
I have the MicroXLR for the balanced output, yes. I am curious about the third output, called the parallel on the Darkglass Alpha Omega that is just a pass through of the input signal. The pass through output isn't showing in the tracing journal, so I am guessing it's just wired straight from the input jack.
I am curious if it might be preferable to use something like a JFET buffer on the through, instead.
Thanks!
Im wondering The same. Did you got it working? XLR and parallel output? Did you bought larger enclosure or did you got those inside original?
Thanks:)!
Thanks:)!
I did finish and it worked fine. Here is my build report for it: Oorang Airedale.
I used a 1590XX case to get all of the jacks to fit - I am not that handy with tight spaces, and only wanted to keep top-mount jacks so I didn't get overly creative to make if fit into anything smaller.
