Little Green Scream Machine + 3PDT Charge Pump Breakout Board?
Polarbear925
Pic is a mockup of a potential project: Little Green Scream Machine with a 3PDT charge pump board at the switch. The questions...
- Has anyone tried this with favorable results?
- Is the wiring diagram I have here correct for this application?
- As I'm setting this up to be switchable, safe bet that the 9v/18v switch is a simple SPDT slide toggle?
Any info helps. THANKS
I'm not sure either, being a noob myself. But I've wondered the same thing. My question would be, does it give more headroom to the circuit at 18v? Again, I'm still trying to learn how that part works.
Looks good but I would just run the jack grounds to the PCB grounds at the top. Make sure you have 35v+ caps on the main PCB.
