What's your opinion about printing pedal graphics using toner transfer?
funky.monkey
What's your opinion about printing pedal graphics using toner transfer method?
Print graphics using iron and printed paper.
(this picture isn't mine I downloaded it from diy guitar effects website)
A lot of people use toner transfer to make a resist for etching.
I guess you’re talking about just using the toner as a finished graphic itself? Seems fine, if you like the way it looks 🤷‍♀️
I’d definitely put some kind of clear coat (might have to experiment a bit to see what works) over it. Otherwise I see it flaking off pretty quickly with use/handling.
Sealing it without melting/dissolving it is the kicker.
Also, getting a clean transfer isn't 100% guaranteed. It's without a doubt the hardest part of etching enclosures.
Yeah, i want to use toners as main graphics.
I tried printing some small logos in the morning, and the results shocked me🫪
1- Mirror the graphics in the pc
2- Print them on a coated paper
3- Transfer them to the aluminum with iron(like pcb method)
4- Wash the printed surface using water
5- Remove the paper slowly from the aluminum
6- Remove the small pieces of paper with a pin
7- Spraying clear coat on the surface
8- enjoying the result 😍👊
I will share the result when I complete my pedal🤘
I don't want to etching the aluminum.
I want the toners as the graphics.
I think clear coat will protect the toners from dirts and sharp things
