Chuck D. Bones
Circuit Wizard
Lotsa good circuits on the Runoff Groove website. Here's another one, the "Umble." There's a good circuit description at Runoff Groove, so I won't repeat it here. I made a few minor tweaks. I used J210's, which have a higher Vp and Idss than J201s. To achieve the desired bias, I changed all of the drain trimmers to 10K fixed resistors and all source resistors to 3.3K. I selected four J210s that produced drain voltages between 5.0V and 5.5V. I installed a 1K gain trimmer between the 1st stage 4.7uF cap and GND so I could dial the gain down just enough so that the 1st stage would run clean with humbuckers. The resistance ended up around 300Ω. I inserted a 22K resistor between pin 1 of the GAIN pot and GND so that when GAIN is at zero, we still get some sound thru. I changed the BASS pot to A250K and the MID pot to A50K because almost nothing happens above 250K or 50K, respectively. Just about any JFET will work here if we adjust the source & drain resistors accordingly. The J210s produce slightly more gain than J201s and have a bit more headroom. The tone knobs, particularly MID, have a different feel from the standard Fender tone stack. Very smooth tone over the entire GAIN range. Highly recommended.
The 1st stage is upper right. 2nd stage is lower right. 3rd & 4th stages at the middle of the breadboard.
Knobs (L-R): VOLUME - BASS - MID - TREBLE - GAIN.
