Twilight Pulse Audioworks Konstante Trace
Gafan92
This is my first post on this forum so I'm not sure if this is the correct location for this. If its not please let me know!
Just wanted to share that I traced the Twilight Pulse Audioworks Konstante and its essentially 1:1 with a Lightspeed and a Chase Tone Secret Preamp.
The main differences are:
Lightspeed side: Frequency pot is 10k Lin instead of Log and instead of 5 1n914 diodes it has a red LED instead of the second 1n914 series. This side also runs at 18v from the 7660. The taper change really is the main difference I hear. It gets much brighter earlier in the sweep than the Lightspeed.
EP side: Instead of the voice switch it has a fixed 10n -> 1m -> Ground.
Should be easy enough to use the order switch PCB, Mach1 and Clandestine Preamp PCBs with these slight changes if you wanted to build one of these. This combo sounds really great together.
