It’s when you think you are good enough to not check the bias range your network is providing and act like it’s normal when you blow a pair of KT77 because your effective bias range is 100-200% dissipation.What’s FS bias? Please enlight me!
That's what I said too, and the developer agrees. So full LTspice import is moving up the work queue priority list since he now has someone who will definitely use it. Some other NAM apps already have editable schematics for selected sims, which I guess is an OK start at least.Thing is, I doubt anyone is dabbling with tone stacks only. For a lot of us, it's all or nothing.
Yeah I can see the benefit of the LTSpice addition there. For my stuff, in the end, I decided against it - I hate it that muchThat's what I said too, and the developer agrees. So full LTspice import is moving up the work queue priority list since he now has someone who will definitely use it. Some other NAM apps already have editable schematics for selected sims, which I guess is an OK start at least.
Again, excellent work on your part though, and I will get to it soon!
Cheers for trying it out! If you want to let me know more in details where you struggled, feel free. Once I found my way of doing stuff, it's difficult to anticipate how else some stuff can be approached by other people. In a lot of instance, there are several ways to skin a cat, but the tone stacks can be complex. There are quite a few prewired examples, but if any are missing, I can add them in. Also don't forget you should be able to drag and drop components OR add them by typing them in the line OR do "Add component" for a new branch from virtually any node.So far, giving it a try, I like it. Some of the things like adding tone stack, etc. takes getting used to, but I eventually figured it out. Will keep working with it - I did a JCM800 mod that I put in my preamp v.1 a couple years back (I'm rebuilding it).
I totally get that. In my case I already have 15+ years of archived solid state Spice models (and plenty of tube ones too), so being able to just port those into Live NAM would be very useful. But for new white sheet tube designs for physical builds I'm definitely all in on using a better tool.Yeah I can see the benefit of the LTSpice addition there. For my stuff, in the end, I decided against it - I hate it that muchPlus I intend this app to basically replace LTSpice for general tube amp building.
