125B - Equilux Mini - UV Print PDF
apierz
Here is a UV printing PDF for the Equiliux Mini. It's designed to look like the Pultec EQP-1 rack unit the circuit takes its inspiration from. It has Color and RDG_WHITE, but no gloss. With 9 knobs its a bit crowded, so everything is sized for knobs around 15mm in diameter. The drill template I link moves the LED hole to the bottom right instead of directly beneath the PCB to make room for the graphics. Be sure to resize that hole depending on your LED preferences.
PDF: Link
Drill Template: Link
As an aside, a Pultec style EQ in a 125B is a quite the feat. This pedal is incredible.
