Add “Mix” knob to Lectric-FX Karaoke Chorus (CE-1) ?
Predictably, this board is still languishing in the ‘to be built’ queue.
Hopefully I get to it before the 2-year mark 🤞;)
What do you wish to do?
  • 1 Have a dry signal and be able to blend in modulation?
  • 2 Have a wet signal and be able to blend in some dry?
  • 3 Have a 50/50 blend, with both dry & wet at max when the knob is at noon?
1) As shown in the OP — insert a pot at R45, the stock resistor feeding the pot.
2) Insert a pot at R46, retaining the stock resistor (or maybe a slightly lower value)
3) Dual-gang with one gang wired to R45, and the other gang wired to R45 — some additional resistor fettling will be required to balance out the two gangs when pot-knob is set to noon.
Option 1 should be fine for my purposes.
Thanks for explaining the other iterations as well though 👍
I’ve got an Aion Small Clone (w/ some mods) all ready to assemble. After that the Karaoke will definitely be my next chorus build.
