For anybody landing on this thread...
Ginsly and I have worked out a switch, SPDT on-on, to have the Q6 final stage toggleable between the starved voltage and reg full +9v:
However... the octave-trimmer...
Looking at the two 22k resistors from the bases of Q4 & Q5 to ground, well, there's simply no room on the vero to place a trimmer that interrupts those 22k Rs to ground.
I've already mentioned to Ginsly that I think the way to go is to match the transistors as closely as possible (and for that matter I'd try to match the two 22k base-resistors and even match the two 100k V1-power resistors) in hopes to not need the trimmer, which is really mainly needed/used IF the transistors are NOT closely matched — in which case the trimmer can tune-in the octave effect.
To add the trimmer I'm thinking another row on the top of the vero could be added, but even so it's a bitch to shuffle components around to make room for the 22k resistors to be connected to the trimmer and subsequently trimmer to ground. The other option is a small scrap daughterboard or just make the trimmer free-floating (with all the resultant problems doing that could entail) ...
Has anybody got an easy way to add that trimmer?
Hmmm... I think I have, now. I was fixated on the trimmers that resemble a little hockey-puck on the board. Instead, I give you...
THIS
type of trimmer. Lift the 22k ends that go to ground, solder them to the outer (bent 90º) legs of the trimmer and the centre-leg soldered to the ground-rail.
BOOM!
Done and dusted.
