BrainDrain
So I'm building the tagboardeffects/layouts version of the Russian BMP. It already has a mid boost switch to add capacitors but I want to add a mid pot too for extra tweaking. Most Russian BMPs look like this to start:
Except the layout I'm using has a 100k resistor instead of the 22k to ground.
The mods say to do this:
Here they replace the 22k with a 3k3 and add the 25k mid pot to ground after it.
So my question is: since the layout I'm using has a 100k resistor instead of 22k would I still use a 3k3 and 25k pot or a higher value resistor and 100k pot?
