drgonzo1969
I have recently aquired some gear that I would like to try out in stereo but I have no idea how to set them up for my particular use. I use headphones pretty much all the time. My main amp is a Carvin x100 head going into a Radial Prodigy load box and I use headphones out of that. I have a Dynachord CLS-222 and a Klark Teknik Dimension D clone that I would like to rig up in stereo. I have a Revv G20 20w head. So I can use that as a second amp for stereo left and right. Both amps have effects loops. I just can't wrap my head around how to set this up. My thought is to put the Dynachord and Dimension D in the effects loop of the Carvin and then send the stereo right to the return and stereo left to the front of the Revv. Then I could use the balanced output of the Revv and the balanced output of the Radial prodigy from Carvin into some sort of rack mixer into headphones? This is where it gets confusing for me. I could use some advice on how to set this up. Thanks in advance. Sorry for the run on sentences and confusing wording. Thanks for reading. All suggestions and roasting welcome.
