Can a paragon`s pcb be moved a tad bit higher?
Ariel
I`m building a Paragon. Personally, I`d like that the knobs placement would be a tad bid higher overall. If a move the entire main pcb higher so the center point of the topmost pot is at 3.1cm from the center line, will i have room for the in/outs? I figure I`d need to connect the main pcb to the custom breakboard with wires instead of pins, so the foot switch placement remain intact, but that`s okay.
