falco_femoralis
Hi all, I'm combing over the schem for the Chalumeau and I'm wondering why the design doesn't use a TL071 rather than the LM386? All the other delay designs use a regular op amp before the delay chip, what is different about this one?
I intend to lift pins 1 and 8 and set the internal gain of the chip to the lowest setting so that I can bypass the fuzz entirely.
After reviewing the data sheet for the LM386 and TL071, it appears that enough of the pins interchange that I may be able to install a TL071 instead of an LM386 with some minimal tomfoolery, with the goal being a cleaner tone with less distortion. Does this make sense?
