Typically, opamps do not make much difference when swapping them out unless there is a specific need for super clean results. Typically, swapping out opamps in, lets say a 'Tube Screamer', there is not going to be any real discernible difference in the sound. EXCEPT where the slew-rate is lower than what the human ear can detect - which is about 0.5V/µs or 0.7V/µs or less. Still using the Tube Screamer as an example, it traditionally uses a 4558 dual opamp - which has a slew-rate of 1.7V/µs. And while the 1458 dual opamp has a slew-rate of only 0.5V/µs, there is no real detectable sonic difference between them in a Tube Screamer. However, if the 4558 or 1458 is replaced with an LM358 (which has a slew-rate of only 0.3V/µs, some human ears can detect that sonic difference. But if the 1458 or 4558 is swapped with an LT1490 (which has a very low slew-rate of only 0.06V/µs), there will definitely be an audibly detectable difference. At least, I can hear a difference. The upper harmonic content seems to be reduced to simple 'noise' with the LT1490.
Fundamentally, the slew-rate specification of an opamp is the speed at which it can respond to an abrupt change of input level - the positive and negative swings if the audio signal it is processing.
There are numerous demos and "shootouts" of opamps on YouTube and other audiophile & DIY forums. It's a Pandora's box for sure - because everyone hears with different levels of distinction. They key is to conduct one's own experimentations. Swap different opamps out see for yourself. It's what many of DIY builders do and/or have done. And in my personal adventure down that rabbit hole, I've come to the personal conclusion that where any group of opamps I'm testing by swapping them out in any given circuit, when the slew-rate is above the audible threshold of around 0.5 to 0.7V/µs - I can detect no audible differences. That's where it comes down to what rest of the circuit is comprised. The biasing, filtering, and compensation components surrounding an opamp in any given circuit is the truer story to the tale of "which opamp is better".
Another and better example is the Rat circuit. Anyone who has built more than a few of them and tried different single opamps in that circuit know the 308 or OP07 chips hit the mark for achieving that traditional Rat sound. Both the 308 and OP07 have a slew-rate of 0.3V/µs. The 741 is a near-neighbor, but IMO, a 308 or OP07 is better.
Some opamps have fixed slew-rates while others are configurable or are dependent on the opamp's gain settings or current setup.
While it is not a complete list, here is a compiled list of some of the commonly used PIN-FOR-PIN OpAmp Equivalents with Slew Rates . . . .
Single Op Amp Equivalents:
CA3130 - Slew = 10V/µs (OTA)
CA3140 - Slew = 9V/µs
LF351N - Slew = 13V/µs
LF356 - Slew = 12V/µs
LM201 - Slew = variable
LM301 - Slew = variable
LM308 - Slew = 0.3V/µs
LM4250 - Slew = variable
LM709 - Slew = 0.25V/µ
LM741 - Slew = 0.5V/µs
LM748 - Slew = 0.5V/µs
LME49710HA - Slew = 20V/µs
MC1439 - Slew = ~6V/µs
MC33171N - Slew = 2.1V/µs
MCP601 - Slew = 2.3V/µs
MCP603 - Slew = 2.3V/µs
MUSES03 - Slew = 35V/µs (very expensive)
NE5534 - Slew = 13V/µs
OP07CP - Slew = 0.3V/µs
OPA134 - Slew = 20V/µs
OPA602 - Slew = 20V/µs
OPA1641 - Slew = 20V/µs
TL061 - Slew = 3.5V/µs
TL070 - Slew = 18V/µs
TL071 - Slew = 13V/µs
Dual Op Amp Equivalents:
AD712 - Slew = 16V/µs
CA3240 - Slew = 9V/µs;
CA3260 - Slew = 10V/µs;
LF353 - Slew = 13V/µs
LM358 - Slew = 0.3V/µs (@ unity)
LM1458 - Slew = 0.5V/µs
LM2903 - Diff. Comparator
LM4558 - Slew = 1.7V/µs
LM4559 - Slew = 2V/µs
LT1490 - Slew = 0.06V/µs
LM4560 - Slew = 5.5V/µs
LM4562 - Slew = ~20V/µs
uPC4570 - Slew = 7V/µs
LM4580 - Slew = 5V/µs
LM833 - Slew = 7V/µs
LMV652 - Slew = 3V/µs ~ 0.12 mA;
MAE2741 - Slew = 1.6V/µs
MC3317B - Slew = 2V/µs
NE5532 - Slew = 9V/µs
NJM4565 - Slew = 4V/µs
OPA1642 - Slew = 20V/µs
OPA2107 - Slew > 9V/µs
OPA2134 - Slew = 20V/µs
OPA2604 - Slew = 25V/µs
OP275 - Slew = 22V/µs
RC4559 - Slew = 2V/µs
TL022 - Slew = 0.5V/µs ~ 0.13 mA
TL062 - Slew = 3.5V/µs
TL072 - Slew = 13V/µs
TL082 - Slew = 13V/µs
TLE2072A - Slew = 38V/µs
TLE2072C - Slew = 45V/µs
Quad Op Amp Equivalents:
LM324 - Slew = 0.5V/µs
LT1491 - Slew = 0.06V/µs
OPA1644 - Slew = ~20V/µs
OPA4132 - Slew = ~20V/µs
OPA4134 - Slew = ~20V/µs
TL074 - Slew = 13V/µs
TL084 - Slew = 13V/µs
TL064 - Slew = 3.5V/µs
TLE2074A - Slew = 38V/µs
TLE2074C - Slew = 45V/µs
Pandora's box is now yours to play with.
