If the issues are anything more than “there’s no audio in the middle position,” and you’re confident in your soldering and components, then the issue is most likely something wrong with the design of the board itself unfortunately.
Unfortunately it is Hit & Miss with PCBMania's PCB's.
Some work & some don't & unless someone else here has buit this Circuit with success, you may not find an answer you want.
