Many__Of__Horror
I have been asked by someone to build them a 2 in 1 pedal for Bass guitar with a detailed EQ side and a compressor side.
At first glance I was thinking the Delegate Comp & the Pro-Filter.
I'm not sure how well these would suit bass? Are there any better options available in your opinion I could check out?
Also is it worth running an effects switcher with them. Would this give the player greater options with these effects?
Also any suggestions on enclosure size to fit 2 x effects circuits. Each is suggested for the usual 125B (H122mm, W-66mm). Not sure if the height would be an issue getting both into a 1590BB (H94mm, W-120mm)?
Thanks as always
Thanks as always
