bidurgi999
Hey everyone,
I just finished building the Median Compressor, and I’m running into something a bit odd that I wanted to ask about.
When I turn the Blend knob, the volume increases up until around 3 o’clock — but once I go past that, the volume actually starts to drop. Is that normal behavior for this pedal?
I’m still pretty new to DIY builds, so I’m not totally sure what's expected.
Also, I set the bias for Q1 by measuring the drain voltage (positive lead on the drain, negative on the DC jack ground) and adjusted it to around 1.85V. Just wanted to check — is that the right way to do it?
Thanks a lot for your help, and hope you’re all having a great day!
