FV-1 Clock Module, 1044 Inverter, and some fun!!
Sturdag Lagernathy
This forum needs some threads, so I thought I'd throw in my hat. All of these are VERIFIED, so have fun!
First up, a super handy inverter vero, for that old fuzz! +9vdc to -9vdc!
Next up, an FV-1 module with adjustable frequency. This has come in handy ALOT. Replaces the crystal oscillator that I never have, plus allows longer delay times!!
Now, if you got all that, but want a bit of a challenge, go with the "Flock Harmonizer"! A fun circuit I HIGHLY recommend!!
If anyone has any Questions, (or requests!) I will try to help. I endeavor to make these very easy to read, even for a beginner. Vero board circuits have taught me so much, I think everyone should be familiar with the method.
Thanks man! Can these inversion boards of you be modified to run ±12, ±15, ±18 etc? Could be handy for stuffing old and new modular stuff into pedal boxes.
I have a board for a Gibson Maestro that uses a regulator and a 1044 to supply -3.3vdc. If you socket the regulator, it should be OK to put any voltage regulator you want. I'm away from my files atm, so gimme a bit...
Ok, this is a board I made for a Gibson Maestro, You can replace the 3.3 v regulator for another voltage, but it only inverts the input voltage. If you want a Voltage double for 18 volts out from 9 volts in, you'll have to wait a bit longer and I'll do it. You could probably find what you need on google or Guitar FX Layouts, Tagboard Effects, or the like, if you can't wait. A lot of layouts you find online are not accurate, whether verified or not, so beware.
