knucklehead
I have a two channel pedal board presently (thank you Boss OC5) and want to run different distortions on each side of it. Doing that independently is simple enough, but I'd like to be able to run multiple distortions on each of the channels - in parallel rather than series - and be able to turn any one or all of them on and/or off.
SO . . . .
Thought was to use a master by-pass switch that sidesteps the parallel signal chain and four individual on/off switches so that a clean signal is not present when the parallel circuit is active.
I intend to use two-color indicator foot switches to make it obvious what state things are in, and isolate ground utterly for both power and signal.
Is this even POSSIBLE? As I think through the circuit options I keep running in to input or output or both silencing the entire box.
SO . . . .
