Help modding Pendulum Harmonic Tremolo schematic, switches for in phase and low pass unaffected?
alonkka
I want to mod Pendulum Harmonic Tremolo (schematic) in two ways and could use some help since I'm not a skilled schematic reader or circuit designer. These are both features I like on my Zepplin Design Labs Quaverato and want to try adding to this pedal.
First, switch between out of phase (harmonic) and in phase tremolo. I believe I would do this by reversing the phase on either the high pass or low pass filter (or bypassing whatever is reversing it).
Second, a switch to pass the low pass side through with no modulation so that only the high pass side is being modulated. (i.e. low notes are not-modulated, high notes are modulated)
Could you provide any details about what I should be looking for on the schematic or doing to achieve this? Thank you very much. I'll post this on reddit as well and update either place if I get a response.
