Hot Kits/Small Muffin Fuzz Drill Template?
Hate to be the bearer of bad news but that's a rebranded pcbguitarmania board.
Probably best off drilling the pots and mounting it in the enclosure sans jacks.
Then reference the datasheet for your jacks and use the measurement from the bottom mount part(PCB side) to center jack to determine the depth of drill needed.
You could always drill a little closer to the bottom of the enclosure as well.
For the DC jack, do the same or just wire one in to the top of the enclosure because who wants side power jacks?
Or just wing it on a bare enclosure and see.
You have a little play as the jack pc pins are longer than the PCB is thick.qs long as the holes aren't to close to the top/face of the enclosure, you'll bee okay. Probably can't put them too low.
Note, you'll want to test this before boxing as you probably won't be able to get it out without desoldering a jack.
on that product page, there 2 pdf, build doc and drill or get here. Or (again) you can ask at hotkits fb group.
iirc, hotkits from Russia. I think Alex Hotkits use alixxx as username at guitar-gear ru.
